aelectricalman
- KY
I'm looking at a group of industrial arc welders that are all fed off one common bus. I plan to perform a power quality study to first determine what is causing the issues of momentary power loss that results in loss of weld strength. The issues happen sporadically and I have a few ideas as to what might be causing this but I wanted to get some unbiased opinions on the matter.
Key points
* There are several welders (dont know the KW or KVa).
* Frequency for which the issue occurs started at once per month. Now it is 5 times per week.
* All are on the same gear.
* PF is around 75% which suggests there is no power factor correction equipment that could be causing harmonic resonance.
* Loss of weld strength is only for 1 second or less (likely ms)
thanks in advance
Key points
thanks in advance
