I have a 400amp 3 phase 480volt feed to a panel box. I have to install battery chargers to this system. Each charger has a lable rating of 15 amps. I called the manufacturer and spoke to the electrical engineer and was told that i could install 26 chargers on this feed and it would be code compliant. I thought you could only use 80% of your total capacity. 15x26=390. Isn't 80% 320amps. Where is the code that says to only use 80% anyway. Whos right?
