At our steel plant, we are installing an overhead crane that will be powered from an open collector/runway "hot rail" system. In section D of article 610-31 it states in part (4) that the disconnecting means shall be "placed within view of the runway contact conductors.
The secondary sub these rails will be fed from is located directly under the rails inside a control room. The breaker on the MDB meets parts 1-3 but with the breaker inside a room does it meet part 4??? If not and I need to install a disconnecting means on a building column, what device meets this article where it states "motor-circuit switch, circuit breaker, or molded case switch"???? What is a "motor-circuit switch"? Any help would be much appreciated!
