dont_blow_up
- USA
- mechanical engineer
Location is WA, USA.
I'm looking to install what I would normally consider an industrial control panel in a new residence. The panel would have a handful of timer relays and 24V controls to control some bathroom fans and electric heaters. I'm struggling with code requirements on whether the panel needs to be UL508 or inspected by an NTRL.
- From what I can tell, NEC doesn't require this panel to be UL508 listed, but it would need to follow article 409.
- WAC 296-46B-903 specifically excepts the definition of "industrial control panel" to not include residential uses. I'm confused here because it's an industrial control panel by NEC definition but not WA state's definition.
- RCW 19.28.010 says that industrial control panels do not need to be listed, labeled, etc: Industrial control panels, utilization equipment, and their components do not need to be listed, labeled, or otherwise indicated as acceptable by an accredited electrical product testing laboratory unless specifically required by the National Electrical Code, 1993 edition.
