Industrial Control Panels - Installations/Locations
Dear all,
I'm new in this forum, I hope someone will help me...
Is it possible to install some panelboards in a control cabin, in my case is a mobile office?
Does the mobile office must have some certificates to install the panelboards inside it?
I'd clarify that the panelboard is classified as "Industrial control panels".
Thanks.
Welcome to the Forum.
You may have a situation where the answer could rely on more specifics and possibly be judged differently in some jurisdictions.
As long as you can meet all the appropriate NEC rules such as 110.26 you should not have a problem.
If the "Mobile Office" is a separate structure outside of another building, 225.30 might cause you a problem, but my experience with industrial applications you will not encounter any problems.
If the building itself was prewired, the local AHJ may require some certification on that wiring.
