Is there any problem with using an Industrial Control Transformer to supply a single phase fan load only? I normally only use general purpose transformers for this, but there are some space limitations and I can mount these high and dry in an enclosure. The transformer is a CE100TH and can be found at this link:
http://www.solahevidutysales.com/pdf/transformers/ICE.pdf
Any thing I should think of before using this to supply a fan load that will operate at 380V fan at 50Hz and 2Amps?
