In most industrial buildings there is typically an underground ground grid that consists of mutliple ground rods and ground rings. The building steel and other items are typically bonded to this system. What codes determine the layout and size of this grid?
With the above system what needs to be attached to this system? Example: 460V motor. Motor is fed from MCC which has a ground bus bonded to this grid and the WYE transfomer is also bonded to this grid. If using type MC cable (3/C w/gnd) to feed the motor and the ground is attached to the motor and also to the MCC ground bus. Does this motor also need to have a ground ran directly from the ground grid to the motor?
Thanks
Thanks
