Todd-Eco
- New York, NY USA
I'm trying to understand the NEC codes related to daisy chain wiring of industrial spaces (warehouses, manufacturing plants, etc). It is my understanding that the maximum allowable rubber cord whip on a fixture is 6' long. Anything longer than this would have to be MC cable (with no restriction on length).
Many companies that I meet with are converting from fluorescent fixtures mounted end to end and going to LED fixtures. The older fluorescent fixtures (end to end) use the fixture as conduit. Many of the new linear LED fixtures cannot be used as conduit, so one of two options come about (Running conduit along side the lights and junction boxes between each light or utilizing diasy chain wiring between the fixtures. I've seen a mixture of items on the market and when I speak to various electricians there seems to be confusion on what is allowable by code.
If you want to mount 4' long linear LED fixtures on 8' centers, you end up with a gap of 4' between the lights. I've seen daisy chain cords offered by some companies. At 110V or 277V what is the code requirement for the allowable daisy chain cord length and wiring to be used. The fixtures I am looking at typically range from 50 to 110 watts each. Can you use UL rated rubber cord between fixtures (if cord is under 6')? Is MC cable required for cords longer than 6'? Are there any other items we should look out for in these types of projects? Thanks for your help.
