Industrial Lighting
jbivens
Is it permissable to use a plug and receptacle hook-up on 400W or 1000W High Intensity discharge 480V single phase lighting fixtures, fed through a remote contactor? The contactor will be fed with a 3 phase 480 volt delta power source from a busway with a high impedence ground. There will be about 54 lights fed off of the remote contactor. We are an Ohio manufacturing plant.
david
Pennsylvania
Re: Industrial Lighting
410.30 Cord-Connected Lampholders and Luminaires (Fixtures).
C) Electric-Discharge Luminaires (Fixtures).
(1) A listed luminaire (fixture) or a listed assembly shall be permitted to be cord connected if the following conditions apply:
(1) The luminaire (fixture) is located directly below the outlet box or busway.
(2) The flexible cord meets all the following:
a. Is visible for its entire length outside the luminaire (fixture)
b. Is not subject to strain or physical damage
c. Is terminated in a grounding-type attachment plug cap or busway plug or has a luminaire (fixture) assembly with a strain relief and canopy
jbivens
Thanks David, we are also wondering if each luminaire has to have its own seperate fuse protection, and what is the minimum cord size and rating?
