Minuteman
- The Sooner Nation
A customer just installed two, used, Overhead Door openers on his shop building. The motor control is "old school" and I am drawing a blank. The up/down/stop control has a 5 conductor cable to it. I figured out 3 of them.
Up and Down have a N.O. contact, and the stop has a N.C.
I can make the up/down work, but not the stop. The customer thinks that UP should be pressed once and the contact on the opener should hold until the limit switch is made. But, right now, UP or DOWN have to be held the whole time. (Release and the motor stops). I believe it is because I don't have the STOP wired in properly.
On the Diagram:
UP = C31 - C4
Down = LS4 - C4
Any help?
On the Diagram:
UP = C31 - C4
Down = LS4 - C4
Any help?
