lochreas
- Seattle, WA, USA
Hi all,
I'm fairly new to industrial settings and want to make sure I'm appropriately sizing a step down transformer. I've dealt with plenty of 208/120 3 phase, but it's the 240/120 that's throwing me off. This is going to be a portable/temporary setup running off of a 480 210kW generator at a small concrete processing facility. The generator is currently only utilizing 63kW and I need to get 240V to run a 17A FLA well pump, a 115V 15A compressor, and maybe 4 other 15A convenience outlets for a small 8A window unit AC and lighting and laptops. So I'm thinking a small 100A panel setup.
As an example, am I understanding this correctly that the 120V side of this xfmr is only rated for a max of 7A? Is there a better way to do this, maybe with a 480-208/120Y setup and then use a buck/boost to get the 1 240V outlet I need?
store.maddoxtransformer.com
3-Phase 480V Delta - 240V Delta / 120
Step-down transformer to convert 3-phase 480V to 3-phase 240V. This unit can be used for reverse feeding. Great for CNC machines, fabrication tools, and more.
