wireman3736
- Vermont/Mass.
Just some questions on the use of thermometers, I recently purchased a fluke 63 I thought would be handy in trouble shooting. I just wondered how to determine when there is an actual problem on equipment or if the equipment may be operating at a higher temp because it is carrying the full load that it was intended for. Correct me if I'm wrong but the marking on equipment means such as 40c on a standard plug in circuit breaker is the max. operating temp above ambient temperature. You can scan through a circuit breaker panel and find a breaker that is running hotter then the others that has a load on it but how would you determine when in fact it is an actual problem or potential problem, same in a main lug panel or switch, if one leg is drawing more then the other you can see one warmer then the other but when is it a problem? any info on this would be appreciated. Thanks Stan
