Ed Carr
- way upstate NY
Just did the rough in of a new inground pool. The pool itself is plastic walls with a vinyl liner. I ran my #8 to the rebar grid which will be under concrete and hit the wet niche,ladder,diving board,hand rail at steps,pump and heater. I also jumpered the aluminum coping all the way around and hit the grid at each end. I then ran a #8 to the panel bonded to the grid. What would be the pros /cons to grounding to the panel. I believe the code does not require it but any thoughts? Thanks, Ed
