Inground pool electrical
fmalgiog
New member
I'm doing the electrical for my inground pool and need to get clarification on a couple of items.
First, is a pool light junction box still required if my subpanel is 15 feet from the pool and my light cord can reach that subpanel?
Second, if I do need the j-box, I know it needs to be 4ft from the pool wall but is there a maximum distance too? Can I put it right in front of my subpanel (making it about 10-12ft from the pool)?
Third, the pool is a steel wall inground pool. How many bonding connections do I need to make to the structure? I read somewhere that I need 4 connections but not sure if that's accurate.
Finally, can I use screws to attach the bonding lugs to the steel framing of the pool or by code do they need to be clamps? (I thought I read this somewhere too)
I am closing this thread, in accordance with the Forum?s rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
I would encourage you to stick around. This Forum has much to offer. But please restrict your questions to areas associated with the engineering profession.
Charles E. Beck, P.E.
