Inspector is requiring everything to be labeled, I have a meter center with a main breaker that has a higher rating than the fault current from the Poco usually this is enough. I am not sure with the meter center main, feeder breakers in the meter center and the tenant panels ( main lug ) these are all series rated, do you still have to do calculations for the above breakers and if so what is the purpose of the factory series rating all of the equipment or does this article just require a label for what is already on the breaker.
