Electromatic
- Virginia
- Master Electrician
I'm looking at relocating a 3Ø,4W service from overhead to underground. There is currently no outside disconnect. The service goes some distance inside the building in metallic conduit to a distribution panel. This is where the GES is connected. I'd like to add an outside disconnect as part of the service relocation but am not sure what to do about the main bonding. If I separate grounded and grounding conductors at the MDP, can the conduit serve to essentially extend the GEC to the outside disconnect where I would then have the main bonding jumper?
