just left a job where i found a 13,800 pad mount transformer with an aluminum plate over the concrete pad in front of the doors. Removed the cover to see what was there and low and behold 13,800 volt cables lay on top of some 120/208 cables. I know the 120 cables are good for 600v but since this is private property and not utility shouldn't there be a divider since the 2 cables are different voltages and that the low voltage cables are not rated for the higher voltage cable present.
would you guys approve this install and pass the inspection?
aluminum cover over the front of a transformer pit.
13,800 cables enter on the left with the red tracer. all the other cables are 120/208.
another view of the same pit. lot of trash in there also.
there is another pad set up the same way with the aluminum plate but did not open that. figure its going to be the same.
Oxidation already started to eat away at the aluminum in the lower right corner of the cover.
