Tetra
- Greensboro, North Carolina
I was working in a house with recently updated panels, the electricians replaced the old panels with new ones and brought it up to code. Without getting into useless info they put AFCI breakers on the bedroom circuits.
I was going through the bedrooms replacing the receptacles and switches.
I had the circuit for the bedrooms shut off at the breaker, and I was checking each with my tictester before getting to work. I got to a receptacle in one of the bedrooms and when i pulled it out i got shocked pretty good, confused I put my tictester to it and it didn't go off, grabbed my meter and checked hot to ground, nothing, checked neutral to ground got 120v (it was actually two neutral wires spliced together I undid them before i got 120v to ground on one of them, and noticed the hallway light turned off when i seperated them!
Long story short the old neutral to the hallway light was damaged so someone ran a length of romex from the hallway light and tied into the neutral of the bedroom circuit, even had the ground and common wires snipped off at each end.
This is where my confusion comes in, the bedroom circuit is protected by an arc fault combo breaker, I thought AFCI's and GFCI's operated by measuring the balance between the hot and the neutral wires, but how come the AFCI never tripped with the neutral from a different circuit piggybacked onto that circuit? Am I to assume the AFCI breaker is faulty? Or am I misunderstanding how an AFCI breaker works? Or was the neutral from one light not enough to make a difference?
