hbendillo
- South carolina
Here is my challenge:
I am lighting a roadway in a park that is about 4500 feet long or so. It is a main road in a sports complex. The owner wants to have a 120-volt duplex receptacle installed on each pole to power decoractive lighting or some special signage with lighting. I allowed for about 1.5 amps per pole which which I think is generous and with the lengths of the wiring runs say from a single point the wires sizes due to voltage drop are quite large. So, we have to set up multiple distributions points along the road with multiple circuits to feed these receptacles. Gets kind of expensive.
Has anybody done anything like this? My thoughts were since we are feeding the lighting on the road with 480-volt circuits, there has got to be a way of tapping that circuit to a small step-down tranformer to feed the receptacle. But where does that happen? Not inside the pole or the fixture head. How about a special pole base with a wiring compartment? I guess we could set a small below or above ground vault near each pole. I am just looking for different solutions for the problem. If you have any product or wiring solutions for this I would appreciate some input.
By the way. The owner wants the receptacles mounted in the upper portion of the pole. so we have to provision the pole for that. Can't mount the receptacle at the base of the pole.
