Installing 16kw shatdby generator with 200amp service questions
Rprilutsky
New User
NJ
Manager
I'd appreciate your help here. I am planning to install the transfer switch inside and it will be recessed in the wall. So all the internal wiring will be behind the sheetrock wall.
  • If I were to use SE cable 4/0-4/0-4/0-2/0 Gray Stranded AL SER (https://www.homedepot.com/p/Southwi...Gray-Stranded-AL-SER-Cable-13107899/205001904) , do I need to use a conduit inside the walls or I need to use a conduit only outside?
  • If the answer to (1) is that I need to use a conduit inside the walls, when I run it through a stud, can I cut the conduit on both sides of the stud (so I do not have to cut a 2” hole in the 2x4 stud). This way I would not have to make a 2” hole (but only 1”) and I will not need additional support for the stud. It seem to be an easier solution. Is this allowed?
  • Can a cable from generator to transfer switch be a lower gauge then 4/0 as the generator can’t output more than 80amp. Can I use 2/0 awg service entrance cable?
  • Is there a requirement for the minimal diameter of the PVC conduit for the 200amp service and for the generator?
I am closing this thread, in accordance with the Forum Rules.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
* This NEC Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
If you feel this action to be in error, feel free to contact me via PM to explain.
A reminder to all members, if you see a questionable post, feel free to report it by clicking report at the lower left hand corner of the post
