installing 3wire receptacles on 1960 home that has 2 wire without ground wire
J R
Does it have to be G.F.C.I receptacle first and regular 3 wire TR receptacles down stream and A.F.C.I protected or GFCI receptacle only then 3wire TR down stream.
Your options are:
*gfci/afci (DFCI) breaker, then 3wire recs
*gfci breaker, then obc afci receptacle, then 3wire recs
*afci breaker, then gfci receptacle, then 3wire recs
* obc afci/gfci(DFCI) receptacle, then 3wire recs- this works when the panel won't accept afci breakers.......
If the panel is one that still available or has been absorbed into those that are still available today - you might even consider dual function breaker. If you are doing a panel change as part of the overall project - I'd likely go that route most of the time.
