I am using a 200A pull out switch model PT224 by Boltswitch:
https://boltswitch.com/pdf/O-1352.pdf
I found a picture online for context, it's a different model pull out switch but the concept is the same.
It takes class T fuses. I want to put in a 50A class T fuses inside the pull out switch but it might be a problem since it is too small. Class T fuses 60A and below have different mounting than above 60A Class T fuses. 60A and below do not have "screw on" type mounting capabilities... Are there any 50A fuses available that have the same dimensions and "screw on" mounting capabilities kind of like the two fuses in the picture.
