Installing cable in a long horizontal chase -- how?
lakee911
Columbus, OH
Good morning,
I have an application where I need to install a fiberoptic cable from point A to point B. There is a 12" abandoned buried pipe that I'd like to use for a chase. I'll be specifying this as part of a larger project that will be bid and completed by a Contractor. Just exactly how might he/she complete the work? I would imagine a pull-string would be used to pull in a rope which would pull the cable, but how does one get the string there in the first place? The inside of the pipe is not clean or smooth.
Thanks,
Jason
I would not be telling them how to pull it, just that the FO cable should be installed in the existing pipe, along with your caveat that the inside of the pipe is not smooth. Let the contractor figure out how to run it. that is his job.
Depending on the length of the pipe it might be as simple as a snake.
Thanks for the response. I'm not planning on telling them how, I'd just like to know for my own knowledge. Also, be nice for costing purposes in case any special equipment might be needed. I also forgot to mention that this pipe is approximatey 1000' long. Sorry for the ommision.
That would be a long snake.
They probably make a pipe cleaning "Pig" used on sewer lines that might work, a homemade one made from a foam mattress could be used. Looks like the biggest conduit one is 6".
http://www.idealindustries.com/prodDetail.do?prodId=foam-carriers&div=5&l1=pulling_products
That's pretty a common animal (nice pun, huh?) in the oil and gas pipelines. I bet they could use one from that industry to pull their rope.
What's going to happen to the other pipes connected to the 12" pipe when high volume compressed air is forced through it?
There isn't any other pipes connected to this as it is a force main from a pump station located approx 1000' away from the plant. There may be some old air release valves that were abandoned in place....those would need to be plugged.
So, that's one method ... any other practical options for this sort of thing?
My first thought is, I would try a radio controlled truck. First I would send it through without a string, to make sure it can get ther, and then I would send it with the lightest smallest string I could find. for you, I would absolutely require that the fiber get install in an innerduct and they can pull a spare innerduct with a pull string.
Going underground, especially through a metal pipe will greatly limit the range of any RC device. What happens when it gets half way through and you can't control it any more? For that reason at least, a retrieval cord of some sort.
Good idea, I was figuring though that you would be able to be on top of it and not lose the signal, but you never know. Another method, that is possible, is an animal. A dachshund going after a treat at the other end would be fine. They live for it.
A dachshund pulling 1000 feet of cord through a rough sewer pipe.
What could possibly go wrong?
:lol:
You guys are funny. We had the same ideas ... RC vehicle and animal. We figured that when the signal ran out now we'd have an RC truck in there to combat. We then thought about a dog, but that's a mighty long way. :lol:
The directional boring machine (assuming HDD type) would be a bit overkill for the job, but it would get it done.
Good call on the interduct! We'll certainly use that.
Lets keep it simple
Lets keep it simple
What about glueing 1000' of 3/4" PVC together and using a 1-liter water bottle slipped over the pipe as a leader? Then pull back your pull rope.
