I am installing a 400A Service using 320 Metercan and coming off the load side of meter can with 2-2" conduits to two 200A disconnects. My question is can I install a J-box and run Bldg steel, water pipe GEC's to a ground bar in j-box and then run #4 to each disconnect to bond the service disconnects. My GEC to ground rod will take place at the meter can per PoCo. All my conductors will be ran exposed( Unless code prohibits). If anyone has a photo of this type of installation and could post it that would be very helpful. The disconnects dont have the required space to make these connections. I do not know how to add pictures on this site.
