Hello, I purchased a home standby generator from Generac (www.genarc.com) called the Guardian,in the installation instructions it states that the generator must be grounded,(they provide a ground connection on the back of the unit), because I live in NJ we are required to have two ground poles installed with at least 6 feet between them these were installed when the house was built.
The generator will be attached to the electrical panel via a automatic transfer switch so when the power fails the transfer switch will automatically turn on the generator and power the house,all of the current ground wires attach to one of the ground poles with a jumper to the 2rd one.
My question is can I connect the ground wire from the new generator to the 1st ground pole along with the ground wires from the electric panel. (I'm only a home owner) Would this be within code???
I did purchase a 5/8 copper ground pole along with the acorns,(this can be returned), should I install a 3rd ground pole and connect all three in series???
I am thinking that since the generator is being attached to the electric panel and will supply all the electric to my home in the event of a power failure, the ground should be attached to the existing grounding poles is this correct..
I'm sorry I may not have enough information about the generator thats why I listed the web site (www.genarc.com) if you need more information to answer my question.
Thank You for your help.. George
