I had a few questions about installing HRG systems and how to wire the neutral resistor. I’ve always been under the impression that this resistor has to be wired in place of the neutral to ground bonding conductor, but I just saw an online video saying you can install it anywhere in the power system. Can someone explain this a little further?
Also I know that on an HRG system, you can use a clamp-on ammeter around all three phases in conduit to help locate the fault. The ammeter will sense that not all three legs are equal, thus a ground fault somewhere. But what if the ground wire is in the conduit as well? The ammeter will always show zero amps because the ground wire is included in the measurement. Am I correct in saying that? I don’t want to mislead electricians when they troubleshoot.
