Re: installing wires in a trench with water pipes,etc
Not to long ago I installed a 100 amp panel in a building behind a ladies home that she was going to use for cutting hair. We installed the feeders, water and gas line in the same trench and yes it was inspected.
By the way I didn?t drive a ground rod at the building either. The water was in plastic so it wasn?t the electrode. The gas supplied the water heater and heat so it was bonded at the furnace. The building was brick veneer, does that give you a hint as the grounding electrode?
