It has been an ongoing confusion as to what type of diconnecting means you should have for instant hot (tankless water heaters). Does anyone know what the proper way to go about figuring out how to connect these water heaters. Some say, "no disconnect", others say "cord and plug" and others say "disconnect switch only". I have been advised to seard NEC code section 422.31. From what I understand this section refers to "appliances". Is a water heater considered and "appliance". I work in a Mechanical/Electrical/Plumbing Engineering firm and all of our catalogs indicate a hard wired connection with no indication of providing a disconnecting means. Another issue is Architects "REALLY" don't like disconnects under the sinks around these water heaters, because the disconnects are bigger than the water heater itself. Does anyone have any insight on this matter so that we can put it to rest?!
Thanks
Thanks
