Gar,
We are getting old aren't we
I also like things simpler and would prefer they not change unless there is a very good reason for the change.
However technology is ever changing and I like to at least make an attempt at keeping up. (but only for a few more years
I agree that power line interruptions/surges etc. should not cause a memory (stored parameter) loss. I have had a few discussions with the Smarthome people over this. Their old Switchlinc X-10 series had the problem and they claimed to have eliminated it in the Insteon product. The very first Insteon device I installed lost its program the first time I switched its breaker on/off.
They evidently have a few things to learn about protecting non-volatile memory.
The advantage of the added complexity allows for many features such as:
1) All lamps can be dimmed and the light brightness is ramped up/down at turn on/off reducing inrush.
2) Lights can be linked together in what are called "scenes" that can provide for some nice mood lighting.
3) The RF link allows for remote PIR control of lights as well as with small remote control fobs.
4) If you add a controller you can write programs and use timers to perform all sorts of more complicated controls.
I got started with X-10 a long time ago and liked the ability to have all my lights dimmed and to have IR sensors control lights and RF remote controls for lighting etc.
I became very unhappy with the poor reliability of the system. The reliability would change every time you added a new electrical device to the homes wiring system.
I do think Insteon is far ahead of X-10 and will be reliable (other than for that pesky -possible memory loss). I intend to include a controller which backs up all the programming to make up for that possibility.
These more complex lighting control systems do require some time be invested in learning about them and programming them. Then of course just when you get up to speed they will change on you
