Designer69
Industrial plant... they want to install instrumentation cable (for vibration sensors, temp. sensors) from the equipment (motors/pumps) to the local controller in free air by installing some unistrut along the routing path and securing the cable with cable ties to the unistrut. It will be armored cable btw.
I am not sure how I feel about this. Reason they don't want conduit is in case they need to replace these cables (many thousands) they don't want to have to pull thru conduit each time.
Any thoughts if this is an allowable design or any issues with it?
Thank You
Thank You
