casualty
- Marble Falls
I have a builder that is using the concrete insulated form for wall construction. He says that once the concrete is poured cured, his electrician cuts a groove in the 2 inches of insulation and installs the nonmetalic sheath cable into the groove. The electrician, then, uses spray foam and closes the groove that was cut in the insulation. The wiring is held in place by foam insulation, no anchoring is needed. The wiring is, possibly against the concrete wall. He said that when they refoam around the wiring that it will be encapsulated. Not sure that I like this. No support or protection.
