We have a 15 KV distribution system, insualted cables with concentric neutral, cables run overhead lashed on a messenger. We are doing some work near these cables and we have been ask to put blankets over them for additional protection and visibility. My question is what type of PPE do I need to wear to install the blankets. I want to spec out the right gear. Do I assume the cable is bare and take the worse case arc flash to determine my PPE based on that? My goal is to provide adequate protection without creating heat stress for the electrician putting on the blankets. Any help would be greatly appreciated.
On a side note we already requested the line be de-energized, however it was determined that shutting off the line posed a greater safety hazard.
