insulated tools
jm1470
I need to buy some new insulated tools and was wondering what you guys use I have look at Ideal but they seem kinda of expensive any ideas.
Dennis Alwon
Chapel Hill, NC
Retired Electrical Contractor
If you mean hand tools then I would say Klein or ideal. I like the ideal strippers but the Klein pliers. Good tools are expensive. The Home Depot & Lowes may have an off brand that are cheaper.
mdshunk
Right here.
If you think the tools are expensive, take a look at the prices of the clothing and safety gear you're required to wear while you're using them.
Fulthrotl
~Autocorrect is My Worst Enema.~
i just bought a set of klien spin tights that were all pretty and orange
from my wholesale house.
not cheap. fat. like trying to tighten a bolt with a grapefruit.
like marc says, wait'll you get thru pricing barbies clothes, the tools
will look cheap.
mickeyrench
edison, n.j.
1000 volt rating
1000 volt rating
some of the industrial co. are following the nfpa 70e with arc fault and i think to be complient you will need the 1000 v rated tools. i don't believe kliens standard tools have any voltage insulation rating. before i buy any tools i would check their rating. i am not 100% sure on this so buyer beware.
don_resqcapt19
Illinois
retired electrician
Given the hot work rules there are very few cases where you are actually permitted to use these types of tools. In general, the only hot work permitted is troubleshooting, and you don't need too many tools to do that.
mattsilkwood
missouri
i just bought a few screwdrivers made by felo. 1000v rated made in germany. they seem like a pretty decent tool but i havent had them long enough to make up my mind.
the best part is they were under 10 bucks apiece.
wdemos
Commerce, Mich.
Wiha/Ideal
Wiha/Ideal
Does anyone Know if Whia is making insulated screwdrivers for Ideal? They look just like my 1000v rated Whia set I have had for a few years.
shockin
I agree. Can anyone give an example of a situation where it is permisable to actually use these tools? IMO all you need is a V-rated screw driver to remove the panel cover and the correct class of meter to troubleshhot with. If your using tools you're repairing not troubleshooting!
zog
Charlotte, NC
Insulated tools are required whenever you are working within the LAB of exposed live parts, table 130.7(C)(9) of the NFPA 70E has a collum that tells you when insulated tools are required for specific tasks.
shockin
Not quite. Table 130.7 is misleading. It gives people the impression that as long as you are wear the appropriate PPE and using V-rated tools it's business as usual. That's not the case. There are very few time when you are actually allowed to work on something energized. In our line of work we never encounter a situation when a shut-down can't be aranged as required by NFPA 70e
whillis
Vancouver, BC
My local Costco has a set of 1000V insulated tools for $35.00. If I remember correctly it has needle nose & linesman pliers as well as some screwdrivers.
I make no comment on the quality because I have not looked at them closely. I'm just putting this out there for anyone who's interested.
shockin
I'll do you one better. I got my Northern Tool and Equipment catalog the other day and they have their insulated tool set on clearance. Eight piece - 1000V for $8.00. (2 phillips, 2 slotted, 2 torx, needle nose, and side cutters) I don't think I'll run right out and buy one.
zog
Charlotte, NC
Sure, you need to have justification as I have posted in the safety FAQ's. http://forums.mikeholt.com/showthread.php?t=99114
But there are some systems that cannot be shut down, like battery systems, you just cant possibly de-energize them, that is a daily task for many service groups.
Table 130.7 is part of article 130, so if you read the entire article it is not misleading, you cant just pick and choose what you want to follow.
jm1470
Has anybody heard of or use wiha insulated tools they are manufacture in germany and the price of the basic kit isn't to bad thanks for the help
