Insulated wire in common hallway
bimmer528
Would it be ok to run rx from an existing outlet to another new install single outlet?
Chicago Condo building
4 floors
Wire run is 10 feet and under the main stairway on the ground floor.
Building 100 years old. All electrical was updated to conduit recently.
Isn't this against code and it should be bx or conduit? When running rx along brick shouldn't result in a violation but could if the inspector was having a bad day. True?
The confusion is differant restrictions on differant floor levels of the dwelling and the building construction type.
