Just a generic PVC conduit box, no threads if I understand your question.We’re are you getting that at?
352.46 Bushings. Where a conduit enters a box, fitting, or
other enclosure, a bushing or adapter shall be provided to
protect the wire from abrasion unless the box, fitting, or enclosure
design provides equivalent protection.
No need to do that read my post just above your last oneI guess you could put in something like this:
Exactly, the question is if there is a consensus that it provides equal protection.Here is the section in the NEC
Yes, besides it is not designed for a bushing. The idea of a bushing is to protect the conductors -- yes you can nick the nylon jacket when installing the conductor in very large wires but the bushing you showed would not protect the wires during installation. I believe there are tools you can use to protect the wire on installExactly, the question is if there is a consensus that it provides equal protection.
That was my thinking but some threads right here such as this one threw me off a bit. Appreciated.Yes, besides it is not designed for a bushing. The idea of a bushing is to protect the conductors -- yes you can nick the nylon jacket when installing the conductor in very large wires but the bushing you showed would not protect the wires during installation. I believe there are tools you can use to protect the wire on install
Yes, that thread is if the pvc has a fitting such as a connector into a box then the threads need protection. There is no connector in an LB......smooth all the wayThat was my thinking but some threads right here such as this one threw me off a bit. Appreciated.
