Brandon Loyd
Is it true that wire of different insulation ratings can share the same encloure, if the lesser rated wire is used for metering purposes?  I found a couple of branch panel with 24V wire installed on CT's for the main feeders, which was not rated for 600v like the rest of the wire in the enclosure.  I thought this was illegal, but was told it was ok if used for metering.
