An old rule of thumb is one megaohm per thousand volts, but most want to see a much higher reading then that.  Also be careful with these types of tests.  You can have a damaged conductor, even with bare copper, and pass a megger test if the conduit is dry and the bare copper is not touching a ground path.  I have seen cases where the megger showed almost infinite when tested, but as soon as the raceway got wet the circuit failed.
Don
