CJW66
- London.Ontario,Canada
Hi there!
Im on a job where we are installing a 2000 amp 600
/347v 3 ph 4w service. Ontario hydro is installing a Transformer on the grounds and we had to install 6 runs of 5" Pvc in a concrete duct bank, and then have to install 6 parallel runs of 4 #600 kcmil RWU 90(plus ground)about 255 ft long, from the xformer to the Switchgear. We are pulling them in this week. My question is about meggaring (insulation test)the wires before terminating them, after pulling them. We used to use the hand crank, but we just got a fluke 1507 insulation tester. I read the instructions and didnt find them very clear. Havent used a meggar for about 5 years and can barely remember how. Cant remember if you hook one wire of the tester to one #600 and one to ground, or do you put one lead on one #600 and the other lead on the other #600 before hitting test? Or both? I have a few guys on my job and feel kind of embarrassed that i cant remember how to even use the crank if i had it..lol. I remember using the crank and having to discharge the wire to ground when we were done. I know i should use the 1000v scale. I tried googling the meter and such but could really only find info on meggaring appliances and motors. Not just a basic feeder test. Any help would be appreciated. Also, the conduits have water in them. Will that have any effect? Should be ok i think as ive heard of companies submersing whole rolls of wire in water before doing an insulation test...Thanks
Great forum btw. Ive been here many times, but just registered today...
