I will likely need to pull new ignition wire to the top of a flare as part of a ignition assembly replacement. I'm looking for some guidance on insulation testing the ignition wire. Wire will be a single conductor 18AWG, 20kV rated, with MICA insulation.
I'm typically used to testing 600V wire at 1000V per NETA, but I'm a little lost on this one.
Thanks
Thanks
