JJME
- Costa Rica
Hello all!
At my work we routinely do insulation tests on the feeders that are run to panelboards, large equipment such as chillers, etc.
We take as a baseline for our own quality control that a cable must have an insulation above 100 MOhm to by compliant. However, is there a problem when the results between two or more readings are different? I don't expect all the results to be exactly the same, but I also don't expect them to be too different.
For example, the insulation test results for a three phase cabling system (A, B and C) I'm looking at are these. The neutral is 'N' and ground is 'T'.
AB: 4,6 GigaOhm BC: 6,5 GigaOhm CA: 5,1 GigaOhm
AN: 4,3 GigaOhm BN: 9 GigaOhm CN: 5,2 GigaOhm
AT: 1,3 GigaOhm BT: 2,9 GigaOhm CT: 3,7 GigaOhm
NT: 3,4 GigaOhm
Look at, for example, BN... it is very different from AN and CN. Also, CT differs a lot from AT.
So the question is: is there any standard, code, whatever that says how much can these results differ from one another? If there is no standard, maybe a rule of thumb for good practice?
Thanks in advanced.
Regards!
NT: 3,4 GigaOhm
Thanks in advanced.
Regards!
