Re: Insurance Claim or not...
I had thought we were too late to offer any additional advice, and that you had already sent the check. If you have not, then my advice is do not. At least not yet. I suggest you consider sending the invoice back to the owner, stamped as ?rejected.? You did not cause this, and therefore he cannot prove that you caused this. Whether you moved insulation or not, and whether you replaced insulation or not, you did not cause this. There is no reason to seek this person?s ?good will.?
Here are some questions that would serve your interests, if this came into a court of law. They may also be worth a friendly discussion with the owner, if the two of you are on speaking terms. Basically, how does he know that your actions made the pipe more susceptible to failure?
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">What other contractors had been in the same area of the attic, doing what kind of work?</font>
<font size="2" face="Verdana, Helvetica, sans-serif"></font>
- <font size="2" face="Verdana, Helvetica, sans-serif">What work had the owner done in this same area.</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">How long had the owner lived here, how cold does it normally get, and how do you know that the freeze did not take place before you had even arrived? That is, was the area cold when you did your work?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">How old is the pipe? How close to failure had it been, and for how long?</font>
But even if you prefer to settle the matter by paying the cost, then consider these points:
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">What else had been damaged?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">What repair bills will he send you next week, after he cashes your first check, and after he discovers that you have accepted responsibility?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">No matter what you say in your letter, if you pay, then you will be deemed to have been responsible.</font>
