MAK
- Massachusetts-Boston
I have a scenario where we are to change out 3 intercom stations in a steam tunnel that is about 700' long. This tunnel is very warm maybe between 120-135 degrees when the ventilation fan is running.
The existing intercom cabling had melted to the inside of the conduit and rendered it useless. The plant electricians had removed the old damaged cable from the conduit by breaking open the conduit @ each coupling and pulling out the old stuff 10' at a time.
The equipment requires a 18-2 OAS that is to home run from each intercom substation to the master station.
So today I was sent out with some 18-2OAS (CMR) cable to pull into a 1/2" EMT conduit in the tunnel. I did not choose this stuff it seems that was what was available at the time.
When we pulled the cable in the jacket had virtually melted exposing the shield. Every time the cable would exit a box or elbow the jacket would stretch and break. I had thought about using cable lubricant to facilitate an easier pull (and less damage to the cable) but was worried if it would just screw things up once it sat in the conduit and baked for a day.
Could anyone recommend a cable that might hold up to the extreme heat that is present in this tunnel?
I have not had to work in this kind of environment before so if anyone had some suggestions I would appreciate your input.
Thanks:smile:
Thanks:smile:
