We are installing an outoodr micro turbine in an areaway that has access doors into the basement. The main electrical room is about 75-feet from the areaway. We are planning to install the main disconnect switch and other controls for the micro turbine within 25-feet of the main switchboard, just outside the electrical room because there is not space in the electrical room. We are also planning to install an non-fused disconnect switch outdoors in the areaway within sight of the micro turbine. The owner is asked that we not install two sets of disconnect switches. We believe they are needed at both locations. Can either disconnect switch be elimiated?
