Energize
- Milky Way Galaxy
For those of you who are under the CPC - California Plumbing Code, which is based on the 2006 Uniform Plumbing code ( I think ) - take a look at page 391 under identification.
A plumber friend of mine called long-distance tonight to tell me he failed his PLUMBING inspection because he used plastic pipe in the house and the plumbing code ( page 391) says if you use plastic, you must put a label on the electrical service panel indentifying the plumbing system as plastic and not metal. He did not have the label, so he failed. Piping was fine.
He says he will fax the page over to me, so I should have it over the weekend when I stop in at the office. He swears it is not a California amendment - it applies to any and all jurisdictions using that paticular code book. I think it is based upon the Uniform Plumbing Code, but I forgot to ask him. It may be based upon the IAPMO codes. (International Association of Plumbers and Mechanical Officials). Then again those may be the same thing. I will have to find out for sure.
Anyone ever heard of this? As a sparky, have you ever been called out for lack of a plumbing pipe sticker on your panel?
EDIT: Spelling and clarification
