LHarrington
- Saginaw Bay area Michigan
Good morning,
Several month ago we had relocated a Grinding dust collect unit about 60 foot from a corner grinder, We had decided to use 6 inch PVC conduit to make the run to and from as vacuum tube. After the work was completed and and we verified we had good draw we assumed it was set forever. Well while observing our work I had noticed the PVC now appears to be wearing a brown sweater. I know we have a static electricity issue here so my main question is how would some of you guy ground this situation. Should I run a bare ground wire through the conduit? One end or both? Any suggestions will be appreciated.
LHarrington
LHarrington
