- Tennessee NEC:2017
- Semi-Retired Electrician
I had an interesting service call today. It was for a light that wouldn't go off with the switch. The customer had already put in a new switch and it didn't help. This was in an office building with just one office effected. I pulled the switch out to check the wiring and immediately saw two white wires on the switch. I thought either someone just used the wrong color or they were switching the neutral. There were two NM cables in the box. The blacks were tied together and the whites were on the switch.
I turned the power off and disconnected the wires. Turned the power back on and touched the two blacks together and the lights came on. Now while doing this, the whites were still separated. So that was a clue right there. I turned the power off, put the blacks on the switch, and tied the whites (neutral) together. The switch now turns the light on/off. I questioned the customer about changing the switch and she assured me that they only took the wires that were on the screws off and put them back the same way. Normally I would doubt someone telling me this but after seeing the wires I didn't see where the blacks had ever had a "hook" for the screws and the whites only had the hooks with no sign of being twisted from a wire nut. She also assured me that no work had been done in the office. As far as I know, I'm the only person in the last 8 years that has done anything electrically in the building.
I have a theory of what is going on with this light & switch but wanted to give others a chance to give their opinion.
