MurphyLuth
- Malibu, CA, USA
I am installing 2 separate solar PV arrays to two meters at the same location. One array is 13 KVA and the other is 35 KVA. Both arrays would be interfaced to 480 VAC 3-phase delta grid power with an earth ground. Most solar inverters want a Wye grid connection. I have contacted the inverter manufacture and they told me that I need a grounding transformer between the grid and inverter. What would be the specifications for this transformer?
