4x4grey88
New User
- San Diego Ca
- HVAC service tech
I am a HVAC tech and am having issues with a 208/240v 3Ph rooftop Heat pump system. Installed about three years ago and ran issue free until lately. First call was "no power" to thermostat. So I looking into why I had no 24v control voltage. Found that the 30A "B" fuse was bad and Breaker tripped, so I replaced the fuse and check the power. System stated okay and I checked the amp draw (12.6/12.8/12.7 on start up) and dropped to 7.8/ 7.7/7.7 Run. So I departed. three days later same issue. again replaced fuse and about the same amp draw as before. I tightened the wire connection and replaced the breaker. three days later again same issue. tried rotating the phases equally (kept rotation). Three days later again.
I am at a loss because I am really not seeing the reason that the one (same) phase keep dropping out without showing were the extra power draw in pulling.
checked compressor (normal), Blower fan (normal), and condenser fan motor (normal) amp draw...
Anyone have a input ???
P.S. This unit is one of five and the others are running normal without issues.
