To hook up an Air Handling Unit, you would typically need flex-cable because the Unit is typically externally isolated (the unit itself has springs on it's base and then it is set on a pad).
You need to install flex-cable because the vibrations from the Unit could cause the rigid conduit to come loose.
If the Air Handling Unit were to have the fan itself internally isolated, would that same rule apply and is there any reference in the NEC that can verify this?
