On a service call, I believe they were sporadically losing a phase (single phase three wire). after much time to finally recreate the problem it seems the problem is at the meter.
I measure each line to neutral and get 120v and 240v phase to phase. Load I get 120v on one phase to neutral and nothing on the other phase to neutral. However I get 240v phase to phase on the load side ???
Why is this?
I never gave much thought to the meter, but I figured it was a solid bar or wire to jump from line to load with current transformers around this jumper.
I told the home owner to get in touch with the utility co. for another meter but I'm scratching my head and don't want to look like a fool.
Why the 240V? Was it reading from one leg to the other through the meter? Do meters break?
I did a search and it looks like this meter has wiring taps and not a single bar or conductor so maybe the meter did fail ??
Why is this?
